TM33 Idle Adjustment
Old 04-08-2009 | 03:33 AM
BassTeQ's Avatar
Default TM33 Idle Adjustment
I've finally got Bills TM33 installed and its running nicely!
Very happy with the improvement in throttle response.
Just wondering where others have mounted their idle adjustment screw, as there is no provision on the carbie itself, I've zip tied it to the frame?
Thanks
Old 04-08-2009 | 05:43 AM
neilaction's Avatar
I hooked mine onto one of the fuel bowl screws.
The left rear from memory.
It's not that easy to get too but I figured how often do you need to?
Old 04-08-2009 | 07:23 AM
MaverickAus's Avatar
Mine just pokes it's head through the little slot in the sidecover not far enough for anyone casually walking past to see but within fingers reach
Old 04-08-2009 | 01:16 PM
b_joannblue's Avatar
I mount the adjusting cable with the same bolt that holds the brake fluid reservoi.
Old 04-08-2009 | 02:02 PM
neilaction's Avatar
mmm might try that.
Old 04-08-2009 | 02:34 PM
neilaction's Avatar
I was checking out Bill's web site wondering whether or not to go for the 351 kit and spotted this pic showing where the idle screw goes. Or at least that is where mine is. Name:  BBcarb.jpg
Old 04-08-2009 | 11:37 PM
BassTeQ's Avatar
Well there you go, learn something new every day
Cheers
Old 04-09-2009 | 06:24 AM
neilaction's Avatar
Cheers
It's quite hard to get to in that position.
If that was a concern and you wanted easy access, Bill's idea of attaching it to the rear brake reservoir bolt might be a better solution.
gc1982
Ninja ZX-9R
05-18-2014 02:17 AM
ghunter
03-17-2010 06:39 AM
zachv17
04-23-2009 02:41 AM
Buzz363
06-12-2008 06:15 AM
hoedogg
Ninja ZX-10R
08-29-2006 01:48 AM
Quick Reply: TM33 Idle Adjustment
