TM 36-68 with a stock bore?
Old 07-19-2013 | 01:52 AM
Originally Posted by duncanblake
I have installed the Tm36-68 on my 2012 klx250s. I have a mix of this forums jetting choices and the results are very good. Some one on this forum said, "If I knew how much better this carb is I would have made it the first change I did to the bike. I agree. I'm having a problem. When I close the throttle completely (corner entry-hard braking) the slide closes down until it is contacting idle adjust rod. as it should. When I start to roll the throttle on (to exit corner) the slide is stuck. I actually have to give the throttle a little yank to get the slide moving. When I'm leaned over as far as I can going as fast as I can this makes the rear tire brake loose. This sucks. The bike is more forgiving than ANY bike I have ridden and it has not bitten me....yet. Anyone experienced this? It's probably vacuum. HELP! Thanks.
I seriously doubt it has anything to do with vacuum on this carb. It sounds to me like the throttle wheel is touching something. I can't imagine the throttle spring tension is too light, as mine seemed quite stong on even the lightest position. There are 3 positions to set the return spring just in case you want to experiment. I'm still thinking you have a cable pinch/kink or something touching the throttle wheel.
  #42
Old 07-19-2013 | 04:29 PM
zippets's Avatar
i have looked around my nieghbor hood @ most dealers and no one carrys these jets
i have heard that you can purchase these jets @ auto part stores also
where has everyone been buying these jets ???
  #43
Old 07-19-2013 | 05:30 PM
I think you'll find that most dealerships seldom carry many of the jets even for bikes that are currently sitting on their floor that have carbs. And in defense of those shops, they'd frankly have to invest quite a bit of money and space to do so. You have to order jets for tuning...usually. I've always ordered a few jets on either side of the stock setting for most of the bikes I've owned with carbs. The jets for my TM36 came from Tucker-Rocky...a big wholesale to dealers outfit...but you can get them from many outlets. Good luck on finding a common auto parts store that stocks anything like Keihin, Mikuni, or other carb jets.
  #44
Old 07-22-2013 | 01:21 AM
zippets's Avatar
thanks TNC
i did find a local racing shop that carrys many different mikuni jets he wants me to pull the jets from my carb bring them down with a list of what i want
so sometime this week i'll be heading on down his way
thanks for your help i'll let you know how this works out
  #45
Old 07-22-2013 | 02:19 AM
durielk's Avatar
Check your local KTM or harley dealer.
  #46
Old 07-22-2013 | 10:43 AM
zippets's Avatar
they actually said that the jets i was looking for was to small for them to carry
  #47
Old 09-07-2021 | 02:30 AM
scubiedoo22's Avatar
Bringing back an old thread... I recently installed a TM36-68 on my '10 250s stockbore and holy crap what a difference. it was installed straight out the box and ran pretty descent. will be hooking up an AFR sensor and Datalogger to get an idea of what the fueling is like. just wondering if there was anyone else running this carb on their stockbore
scubiedoo22
06-04-2022 02:59 PM
MADDOG2007
10-19-2011 06:42 PM
dualsportman
09-04-2009 12:52 PM
buffalony
09-22-2008 12:36 PM
mudjunkie
06-28-2007 01:59 AM
Quick Reply: TM 36-68 with a stock bore?
