Tire size help
Tire size help
So i have been searching around and am having a hard time understanding and finding the correct tire size. The stock size is 4-60-18. I am replacing the rear and want to go with the Cheng Shin C858. I am on bikebandit and these are the sizes for an 18 inch rim:
80/100-18
90/100-18
120/100-18
I would prefer not to get a taller tire due to the fact i am close to tippy-toe at 5'6. It seems like the 90 would be too skinny and the 120 too wide, i don't even know if thats the correct way to read them as far as width. But to me i wouldn't mind a little wider tire.
Also i was looking at the Kenda K270 which i have seen and heard alot about on this forum but their sizes are:
3.50-18
4.00-18
4.10-18
5.10-18
4.50-18- would this one be the closest to stock?
Any help/suggestions would be greatly appreciated.
-Nick
80/100-18
90/100-18
120/100-18
3.50-18
4.00-18
4.10-18
5.10-18
-Nick
http://tiresunlimited.com/ALL%20TIRE...Dualsports.htm
http://www.chaparral-racing.com/Chap...1BC80C78B34977
Found two sites with 4.60-18 sized Chang woo tires =) I believe the stock tire is a 100/100-18. The 90/100-18 would be about 1/2" thinner and 1/4" shorter. The 120 seems a bit big for what you want. Do a search for "motorcycle tire chart" and you can find some usefull info.
Thanks for the info, now i get it for the most part. I decided to go with the Kenda K760 Trak Master II. It seems like a more off road than on road tire. Like a 80%off / 20%on. The size ended up being 100/100-18 so it should be just like stock size.
-Nick
-Nick
It takes 80 to 100 miles to break the Trak Master in on the street so reserve judgement on it until then. After that period it's a little better on the street. Enjoy.
Mike
