Tire replacement...110/70x17 to 120/60x17?
I need to replace the front tire on my 09 250SF and the dealer is trying to convince me to go with a 120/60x17 as a replacement. What do you guys think?
According to the dealer, going to that size will broaden up my tire options and provide better handling without affecting the geometry of the bike.
I really don't want to mess with the OEM setup/recommendation in regards to tires however it may be a wise choice.
Thanks
Thanks
You might try to put those two sizes beside each other, the 110/70 calculates to be taller than the 120/60 throwing off the speedo and dropping the front end slightly if you switch to the 120/60.
Thanks
Thanks
I know I can run as hard as I want while chasing a DRz400SM, super motoed XR650R, and Aprilia SXV550 friends ride. I can't motor the 650 or Aprilia, but can hang real close in cornering with my Duro HF903/904 17/21 dual sport tires. Might be different on a track where I wouldn't have to deal with variables pubic roads present. I want a set of roll in 17s just to keep from wearing the dual sport tires so bad and for the look, but I won't sacrifice the 21" front for my dual sport use.
shinobi636
06-18-2007 07:45 PM
