Tire recommendation
Old 11-14-2017 | 01:52 PM
Originally Posted by gedenke
The Parkers are interesting...how do you think they would do in my climate? With the exception of summer months, it's more wet/damp than dry around here the rest of the time. Sounds like they may last a little longer.
I need to correct something in my previous post about the Trakmaster. My side **** tearing was only on the front. The rear was super durable with no chunking of any kind.
On the Kenda Parker, I found it to work in wet conditions as well as most other knobbies I tried. Knobbies that work well in wet/muddy conditions almost always shred quickly in rocky, hardpack. Don't let the "desert" designation scare you. It's there just to accentuate where the tire excels...especially the resistance to **** chunking in rock. I've never found the Trakmaster or Parker to be prone to packing up in mud...at least not any worse than any other knobby I've tried over many years.
Old 11-15-2017 | 03:06 AM
gedenke's Avatar
So after a little research, I think I'll give the Trakmaster a try. The Parker is appealing for the harder compound (longer lasting?), but the smallest size is 110/100-18, 12 lbs, and more expensive. The Trakmaster is cheaper, comes in 100/100-18 (stock size), and weighs 10 lbs. If I take klx678's advice, the 100/100 would better suite my needs.
Thanks for all help guys!
Old 11-15-2017 | 05:17 PM
Werloc's Avatar
Trakmaster’s on the rear with Southwick’s up front is what I’m happy with. I ride mostly soft sugar sand here in south NJ. Do some rocky terrian up North Jersey and PA. I love the price of the Kenda’s and they’re both DOT. They hold up pretty good for me since I try to avoid pavement, but do ride some. I had D606 which worked ok on rocks and hardpacked terrain, but were really bad everywhere else. You can’t go wrong with the Trakmaster on the rear, but they aren’t so great up front. They don’t work as well on the front like they do on the rear in any terrain. To each his own though. Asking about tires is close to asking whats the best oil. BTW, not one tire will do it all. Choose a tire made for the terrain you ride the most on, or for where its most important to perform well for you.
Old 11-29-2017 | 02:47 PM
Dirtbkedan's Avatar
I just used up a trackmaster last season and found the rear to be very noisy on the road not at first but after it wore in a bit. The front still has lots of life left, both where installed about 1500-2000kms ago.
Old 01-12-2018 | 04:31 PM
reinigef's Avatar
I found this tire size comparison tool useful. Just plug in two sizes to compare, even gives you the deviation in speed between the sizes.
Stock rear is 100/100-18 BTW.
https://www.tacomaworld.com/tirecalc...0r18-110-80r18
TheKawiKid88
08-23-2024 12:56 AM
002197rp
10-23-2007 05:11 PM
aalegado
10-22-2007 08:02 AM
thack79
ZZR 600
10-09-2007 02:41 PM
Nobrakes
06-20-2006 10:30 AM
Quick Reply: Tire recommendation
