Tire Pressure
I have my tire pressure set at 13F and 14R. (Stock Dunlop 603's and no rim locks) I ride in mostly dry and rocky terrain. I understand that the wetter looser the conditions you should use less pressure. I don't have that much experience to relate to and was wondering what everyone else is running and how it is working for them.
I would recommend around 16 - 20 PSI. This should be ample and not require rim locks. If you want to go lower then look into rim locks. I don't think this bike has enough torque or power hit to worry about it to much though.
ORIGINAL: mmatz
+ 1 on the recommended tire pressure.
My dirtbike tires had a recommended 15 front 15 rear for track riding but they had rim locks as well so we would drop them down to 10 f, 12 r when riding in deeper sand.
I would think the min pressure you would want, ex rim locks is 15 F&R, but I would think that for the type of riding your doing, 16 F and 18 or 20 rear should be spot on....
ORIGINAL: incabiker
So if you don't have any rim locks and don't plan on getting any what would be the safest bet for the road and the dirt?
Funkdock
04-22-2006 01:43 PM
