Tire choice is overwhelming! I need your help.
Does the job nicely
Took both front & rear down to about 10-12psi, in the garage close to the air compressor, just in case. Had em both back to 22psi 3-5 min with the new Mountain Morph that TNC recommended. Sweet! I've been reluctant to air down with no way to air up for the ride home. This is going to work for that and flat repair.
I believe all Kenda MX fronts are DOT. I really liked the Millville sticky I had on mine.
On 8/28/2012 7:43 AM, Gus Niewenhous wrote:
Front MX tires are DOT approved.
MX Tires
K780 SOUTHWICK II - Front DOT Approved
K785 MILLVILLE II - Front DOT Approved
K775 WASHOUGAL - Front DOT Approved
K781 TRIPLE - Front DOT Approved
K782 SAND MAD - Front DOT Approved
K772 PARKER DT - Front and Rear DOT Approved
K335 - Front and Rear DOT Approved
KENDA Powersports Division
Gus Niewenhous
Sales and Marketing Manager
gniewenhous@kendausa.com
614.729.7878
7095 Americana Pkwy
Reynoldsburg, OH 43068
MX Tires
Gus Niewenhous
614.729.7878
7095 Americana Pkwy
Are they marked "DOT" on the tire? At some point it's very likely you'll run afoul of a zealous ranger if you do much riding in BLM, forest, or state public lands. I'm not sure if it's revenue pressure or what, but in the last 3 years I've had more questions and inquiries from rangers about my tires being DOT than I've seen in all the decades before. I think most of us know it's not so much the tire being any better but mainly relates to whether testing and certification was obtained by the manufacturer.
I had the TMII on the rear at one time and it was the only one that ever chunked the *****; is this a characteristic of the TMIIs?
Not from my usage experiences. Like I said earlier, selecting tires for someone else, even on relatively the same bike, is hard to qualify. I've never chunked front ***** like I have with the KLX. I think some of these issues isn't just where you ride but how you ride to some degree. Nearly everywhere that I ride in my home area or out west mainly consists of rocky terrain. You'd think all my rear tires I've tried would be toast relatively quickly and with some **** chunking. Frankly I've been impressed that the least expensive rear tire I've used, the TMII, has been the least likely to chunk and lasts as long as anything else I've tried to this point. I don't ride much pavement, and what pavement I do is seldom over 55mph. Not sure how this compares to other riders. Plus, I don't wail on the throttle in sketchy conditions or rocky ledges and such. My KLX has such good low end, that I seldom slip the rear tire. My front tire does get punished to a fair degree. I braked hard and late with the front. It's the way I've always ridden. Where my race bikes in the past were usually around 250 pounds or less, my KLX is probably around 300. And when I'm out on my traveling trip rides, I carry more stuff than I ever carried on a race bike. I don't compare tire wear on the KLX to any of the KLR600/650's I had, because the KLRs are freakin' boat anchors. I also weigh about 190 nekkid.
