Time for New Sproket and Chain
Could you elaberate on how to put saftey wire on the masterlink? I just cant picture how one would go about it?
Cheers Jim
The masterlink has the retaining plate just under the clip. I like to put two winds of SS safety wire around the plate and clip twisting the wire lightly, leaving a small end of the safety wire. This can easily be tucked back against the chain. The small diameter wire will not impede on the sprocket O Ring and sprocket clearances. Just to aide my quick pre ride inspections, I put a dab of Blue RTV sealant on the twisted wire to make sure it is still there. (The same stuff as I use for my axle pinch bolts.) I have seen a lot of flying chains off of the starting grid due to missing links.
Interesting. I've never thought of doing that, Drag. I have lost a clip before, though. Luckily the chain stayed together even without it until I spotted it missing when I was doing the pre-check before the next ride.
Good to see you back, Gravy.
1camwonder
12-15-2013 06:13 AM
rayw1128
06-06-2007 02:10 PM
