Throttle restrictor on carb
Old 06-07-2011 | 01:45 PM
nornalup's Avatar
Default Throttle restrictor on carb
Ok excuse this question as I am sure there is a really obvious answer, however. On the side of the carby the two throttle cables are connected to a part that controls throttle opening and closing. Idle speed is controlled by a adjustable screw, WOT is controlled by physical shape of this part.
Now my question is can this physical piece of metal that controls the maximum amount that the throttle is opened be moded (ground back a few millimeters) to increase the throttle opening?
Does that even make any sense?
Old 06-07-2011 | 01:59 PM
Now I'm not totally clear on where you're going with this, but are you saying that you believe the throttle butterfly is not opening to its wide open position in stock condition?
Old 06-07-2011 | 05:02 PM
linkin5's Avatar
No it can't.
Old 06-07-2011 | 06:37 PM
David R's Avatar
Another customer looking for the "magic screw" That only us mechanics know about.
" I have this moped. It only goes 30 mph. Is there some screw I can turn to get it up to 45 or so?"
Sorry,,,,,
My attempt at humor
David
Old 06-07-2011 | 06:42 PM
Sorry,,,,,
My attempt at humor
David
You didn't finish...45mph and 200mpg.
Old 06-07-2011 | 07:23 PM
PSUdude85's Avatar
I believe that's what the OP is saying.
OP if you've ever seen the butterfly with the carb off you will see that it is full open at WOT, therefore grinding the bracket back will not do anything except for damage the carb probably.
Old 06-08-2011 | 01:59 AM
nornalup's Avatar
Thanks PSUdude85, thats what I was trying to allude to in a not very clear, know very little about carb terminology kind of way. I was told that straight from the factory a throttle restriction was in place and I figured this may have been how they did it??
Old 06-08-2011 | 11:59 AM
PSUdude85's Avatar
I don't recall any type of throttle restriction, but there is one hell of any engine restriction which can be solved by removing airbox, rejetting the carb, and adding an aftermarket exhaust to it!
Old 06-08-2011 | 12:37 PM
maninthesea's Avatar
Just clarify for Noralup- PSUdude85- intended to say remove the airbox lid you do NOT want to remove the whole airbox.
Old 06-08-2011 | 03:38 PM
RayTard's Avatar
I'm going to verify 100% whether or not the bike can go 100% wot, or not ill post up my results after work.
neonarc
06-28-2015 02:58 PM
Kor
08-11-2013 09:13 PM
kyrral
05-05-2013 02:56 PM
eas
02-21-2008 12:36 AM
sbdiehl
10-29-2007 03:15 AM
Quick Reply: Throttle restrictor on carb
