Thinking extra gas.......
Old 02-14-2016, 01:36 PM
Dash8's Avatar
Originally Posted by Werloc
Dash, This is "about" (give or take a few pages) where they start talking about it. It's almost 700 pages all about the KLX250. A good long *** thread to go back and read on a rainy day. Tons of info.
Long term KLX250S review | Page 653 | Adventure Rider
Awesome, thanks! I was being lazy and hadn't gone to find it yet lol
  #32
Old 02-14-2016, 08:55 PM
Originally Posted by dpippin
You have to modify the throttle actuator on the pumper carb. You need to cut off the top part of the actuator wheel to clear the fuel tank. Then you only use the pull throttle cable for throttle operation. Once you make this modification everything fits fine.
Mikuni TM 36-68 Pumper Carb
Doug
Are you positive the throttle actuator needs modified for the IMS? I know it does for the Acerbis (been there, have it), but don't recall the same modification was needed for the IMS. Just curious.
  #33
Old 02-15-2016, 12:41 AM
Originally Posted by jeepkevin
I was in the same boat. I have had the oversize tanks on other bikes and they worked just fine. My only complaint was that the added weight was over the front of the bike. On this bike I decided to go with the small PMR rack and add a 1 gallon Rotopax when needed. I redrilled the mounting holes on the rack so as to turn the gas tank sideways and move it as close to the seat as possible. This allowed me to install the factory vinyl pouch after the gas tank on the end of the rack. This set up makes a nice flat surface for me to strap my expandable back pack on to for whatever crap I need to carry.
Also sets up for a shorter "lever" making it less stress on the subframe where it might break. Makes sense.
  #34
Old 02-15-2016, 12:44 AM
Originally Posted by toomanytoys84
Painting a plastic fuel tank is a losing battle. I've never had one successfully stick. I have read that this is because fuel vapor leeches through the plastic and breaks down the paint.
Part of the deal with the red plastic is there is an additional layer that will not allow the fumes to leach through or makes it far harder to do so.
Plastidip would probably work since it is essentially a coat of vinyl and won't peel like paint or stickers. It would just have to be thick as possible. Like real plastidipping would be.
Ratkiller
08-28-2007 03:59 AM
hoedogg
11-12-2006 06:45 PM
a16tony
06-16-2006 08:51 AM
NavKLX
05-22-2006 09:24 AM
zixR
07-23-2005 03:37 AM
Quick Reply: Thinking extra gas.......
