tank vents
Old 07-18-2008 | 06:19 AM
RaceGass's Avatar
Default tank vents
I've been looking into lightening the klx. The fuel tank has 3 vent lines under the tank.
Old 07-18-2008 | 06:20 AM
RaceGass's Avatar
Default RE: tank vents
ONe goes to where the carb vent lines terminate. The other 2 hook up to the vapor canister,no mention in any posts what should be done when removing that item.
Old 07-18-2008 | 06:22 AM
RaceGass's Avatar
Should the 2 vents be blocked off? Or since they might cause vapor lock...
Old 07-18-2008 | 06:25 AM
RaceGass's Avatar
They be routed in a different way? Anyone have a tip/suggestion?ThanksMike
Old 07-18-2008 | 09:58 AM
neilaction's Avatar
Go plastic tank.
Problem solved.
Your venting sounds way different to mine. (maybe the 09 is greener?)
I had 2 long rubber hoses that ran down along with the other carb vents.
They weren't connected too anything.
I had no Idea what they did as they seemed way over the top to be just tank vents.
But with the Clarke tank, they were not needed.
Old 07-18-2008 | 11:41 AM
my bike only has 2 lines off the bottom of the tank..... maybe different on the 09's?
Old 07-18-2008 | 04:35 PM
marc11's Avatar
If it is a 2009, it may have CA emissions so one would go to the charcoal canister. But to be honest, looking to save weight by removing a little rubber hose is clearly not the way to go about it, you would save more weight by taking a dump before you took a ride, seriously....
Old 07-18-2008 | 06:01 PM
Bad Bear's Avatar
I had 2 hoses also I now have the Clarke tanf and just put a new Billet cap and 8 ball freeflow vent works wellThe plastic cap was getting some splits in it as they all do over time
Old 07-18-2008 | 08:19 PM
Kawi Wawi's Avatar
lol, I agree,take a dump before you ride...
Old 07-19-2008 | 02:08 AM
Hardtaco's Avatar
check your email racegass, i couldnt get my PM function to work.
Josh
