Tail Light System
Old 12-24-2009, 07:37 PM
TNC is offline
I love that Ocotillo Wells/Anza-Borrego area. Split Canyon and many, many other trails in that area are great.
  #32
Old 01-09-2010, 03:58 PM
mikey113's Avatar
I just got my edge tail light system today. It says not to use the stock flashers. If I do use the stock as some of you have, will I do any harm to the brackets that would mess them up if I wanted to go with the smaller flashers in the future?
  #33
Old 01-09-2010, 06:54 PM
barbz's Avatar
no harm - I found i had to grind a tiny bit of the metal bracket that you screw into - to get it to fit.
Make sure you do it slowly and make sure its perfectly flat - this will stop the signals flopping around (so stop and test the fit continually).
Well, this is how I got them to fit; it all fits together and looks the part. Just strip the old stuff off and have a look at how to get it to work.
Paul
This will not affect anything should you want to put it back to stock.
________
Cheap Portble Vapourizer
  #34
Old 01-11-2010, 04:59 AM
mikey113's Avatar
Default Project edge tail light completed
Hey Barbz,
I figured out what you were talking about after I'd cut off a bit too much of the stock flasher holder. I reinforced it with a specially grinded flat washer on each side and they feel secure. It took the better part of the afternoon as I had to make to runs to the parts store for wire connecters. I didn't use the provided ones. Other than that everything went smooth. Thanks for the input.
  #35
Old 01-11-2010, 05:18 AM
barbz's Avatar
Good stuff - I cut too much off one side before figuring out what impact it had. Second side is spot on.
If i get energetic I will fix it at some stage but until then it doesnt move around enough to cause a problem.
Cheers
Paul
________
*** Cam
  #36
Old 01-11-2010, 06:20 PM
punkenduro09's Avatar
mikey, nice rear tire. i love the nomatic rack with the edge2.
  #37
Old 01-11-2010, 08:44 PM
mikey113's Avatar
Thanks, the rack is great, I have an old wolfman pack (1st generation) with 4 bungee cords coming out each corner - a $20 ebay find. It works like a charm.
  #38
Old 01-12-2010, 03:58 AM
slippery750's Avatar
I wish Edge would make a brighter led for their kits, the smoked one is a let down on intensity and sets you up for an accident!
  #39
Old 01-12-2010, 04:59 AM
mikey113's Avatar
Last week before I got my UPS I called Forest at Wheeling Cycle and asked about my order. When I was on the phone with him out of curiousity I asked what a replacement lens cost, he said $5. You could order yourself a red one to replace the smoke. BTW that was my fear with the smoke lens. Thanks for confirming my su****ion, well that and what a cop might say about its street legal-ness...
  #40
Old 01-14-2010, 12:18 AM
Thanks for the pricing info, but too late I made my own.
https://www.kawasakiforums.com/forum...ad.php?t=30027
Jammin'John
2000 & 2000 Limited
11-14-2012 12:14 AM
Jammin'John
11-12-2012 11:42 PM
Tdizzle
04-18-2009 06:29 PM
Ratkiller
05-03-2007 03:12 AM
Quick Reply: Tail Light System
