Tail light doesn't come on
Old 04-05-2013 | 05:44 AM
RockabillSlapMatt's Avatar
Default Tail light doesn't come on
So my brake lights works, and so do my blinkers, but when I'm riding at night I have no rear brake or license plate light? Do you guys know what could be the problem
Old 04-05-2013 | 06:26 AM
Lotrat's Avatar
Blown bulb?
Blown 10a lighting fuse?
Broken wire?
Bad connector?
Old 04-05-2013 | 07:32 AM
Originally Posted by Lotrat
Blown bulb?
Broken wire?
Bad connector?
It cant be the bulb the brake light and the license plate light works ONLY when the brakes are applied
Old 04-05-2013 | 08:28 AM
Lotrat's Avatar
You mess with the wiring? Did you mix the tail/license plate light wire with the brake light wire?
Old 04-05-2013 | 02:07 PM
go cytocis's Avatar
The tail light bulb has 2 filaments; both of them are still OK?
Old 04-05-2013 | 03:43 PM
795.0pacecar's Avatar
Check the bulb, the license plate and tail lamp use the same bulb for illumination. So with the key in the on position both should light up and when you hit the brake and tail light and plate light should appear brighter.
Old 04-05-2013 | 04:20 PM
ahnh666's Avatar
ditto...the bulb is 2 filaments...99% sure your tail light filament is out....your brake light filament is probably still okay...make sure you get the correct replacement bulb...many bulbs will fit and work, but if you replace it with the incorrect watts, it'll burn out again in few months or sooner (made that mistake once)
Old 04-05-2013 | 05:37 PM
*bows down* you guys are geniuses, the filament was broken, I had no idea the bulb has two filaments, nor did I know that when your tail light fall out and bounces around that a filament can break. well know I know I suppose.
Old 04-05-2013 | 05:50 PM
ahnh666's Avatar
and, you'll notice that's it's always the tail light filament that burns out first before the brake light....i don't know why, but that is how it always has been on my cars or this klx....
Old 04-05-2013 | 10:18 PM
Tail light filament is burning any time the bike is on (or in a car, anytime the lights are on),,,, brake light filament is only energized when brakes are applied. Much more "burn" time on the tail light filament.
