Switching off headlight to free-up some watts?
Trying to understand .
Dan
Good question, Dan. I'm guessing that sometimes there can be a high-resistance ground that can sometimes occur, even when the ground wire circuit is open (switch off), so that a little juice passes through the lamp. In the case with the X2, it's all plastic and rubber connections from the lamps to the bike frame so I don't see where any stray juice can get to ground, except through the switch if it wasn't completely opening the circuit. If the circuit isn't completed in any way, how can the lamp use any juice? But that's all just guesses, part of which is based on some funky house wiring I've ran into in the past.
I've never heard of put a switch on the ground to kill the headlight. I would think putting a switch on the hot wire going from the fuse block to the headlight would get the result you would be looking for. You would be opening the circuit from the primary power source therefore not allow any voltage through to power the light.
I just took a quick look of the 2009 wiring diagram that's in the stickies.
If the earlier bikes are wired the same way, I wouldn't put a switch (or a relay) on the ground wire going to the bulb.
If you open that connection the Hi-bean indicator light in the dash will provide the ground path. Meaning, the headlight bulb will glow faintly and the hi-bean indicator will be always on (as long as ignition is on).
Correct place for a switch to turn off the headlight is on the positive wire going into to the hi/lo handlebar switch.
Mikko
Mikko
Time for a six pack and a solder gun
Just be sure to flip the headlight back on if you see a cop, in a lot of states that could result in a fix it ticket. In my case, I'd risk an inspection.
Law: So, where's the evaporative emission system?
Me: Ummm, in a cardboard box in my garage, sir...
Yeah, the bulb has three connections, ground, high beam, and low beam. If you cut the ground, any voltage on either of the two hot leads will find it's way to ground through the bulb filament and the bulb will glow a bit. If the voltages on the hot leads were equal, the bulb would not glow, but because of differences in the length of wires and where things connect, this is very unlikely. I also speak from experience here -- I tried the switched ground lead idea many years ago and learned the hard way.
You COULD use a double pole switch in the hot leads, but even the OEM headlight switches on bikes tend to fail over a relatively short period of time. Relay contacts are designed for high current and are typically more reliable because the relays are sealed and out of the weather.
I got into this on my 96' TW200. I thought a simple ground wire switch would work. WRONG. I still had dim lights. I ended up stripping the entire wiring harness and running a new hot to the ignition switch, then hot side switch. I was wanting a complete blackout switch. I had to seperate the lighting circuit from the ignition circuit otherwise the blackout switch would also kill power to the ignition relay. Still, when I turn off the bike the lights stay on until I turn off the new switch and they want come back on until the ignition key is turned??????
I scratched my head on that project for a while!
I've studied the KLX wiring diagram and still haven't got a good game plan. I just don't want to strip that harness too. I've alsoo heard that without the lights the battery could be overcharged. SO FAR my TW is fine but I'd like to know if that's true before doing it to the KLX.
I'll see if I can find it later, but for now: there is a thread here that shows a circuit that keeps the headlight LO off at start-up until you hit HIGH beam. Then the lights work as normal. But the bike needs to shut off again to reset the circuit. So you can't kill the lights anytime you want. I have an aftermarket switch for a KLR650 that has an off position but I need a dead '09 left control with the harness intact to be able to wire it in (I want to be able to save my stock control/harness in case I need it again)
