suspension settings, where does everyone have theirs set
Old 06-22-2007 | 02:55 AM
dmar's Avatar
Default suspension settings, where does everyone have theirs set
Where does everyone have their suspensions set (stock suspension). How many clicks out front and rear, rider weight etc. I just adjusted mine to manual settings minus one click, Iam about 165# rider.
Old 06-22-2007 | 06:44 AM
digitaloverkill's Avatar
Default RE: suspension settings, where does everyone have theirs set
I'm about 5'7" and around 140lbs on a rainy day. the only thing i changed was the rear nitro shock i guess it is and I have the top side of it all the way in (turned right) and from there out one click.
Old 06-22-2007 | 01:01 PM
JB1's Avatar
JB1
https://www.kawasakiforums.com/m_67995/tm.htm
Old 06-23-2007 | 12:46 AM
FM_Thumper's Avatar
I'm 185 lbs "dry weight". With gear, I'm going to guess 200 lbs...
Front Forks: 4 turns out. 5 turns out seems the best for street but it bottoms out off road, hence the 4 turns out.
Rear Spring Preload: Stock
Rear Compression: 14 turns out
Rear Rebound: I currently have it at the stock 12 turns out. I have not really experimented with it. I plan on however...
Old 06-23-2007 | 12:48 AM
Notstock's Avatar
Clicky
Set the bike up for your self then adjust.
Old 06-23-2007 | 03:34 AM
plameau's Avatar
110mm of sag, 12 out on rebound. Forks flush with the top of the clamps full stiff on the clickers!
Old 06-23-2007 | 11:52 PM
FM_Thumper's Avatar
ORIGINAL: plameau
I take it that you are a pretty big dude...
JasonFMX
08-21-2008 04:03 AM
speedracer138
07-24-2006 09:22 AM
beersnob
03-05-2006 07:41 AM
md636
02-28-2006 01:33 AM
05Zixxer
Ninja ZX-10R
02-12-2006 12:27 AM
Quick Reply: suspension settings, where does everyone have theirs set
