Surge at 6500 rpm at highway speed
Old 05-15-2012, 11:38 PM
klx250s_s's Avatar
Originally Posted by inroads
I bought my bike and the previous owner had installed a #40 pilot and 125 MJ(keihin).It ran ok and I never noticed a surge.
Then I was searching for optimum MPG and I went back to the stock#35 pilot and down to a #120 MJ(keihin) and am now noticing a surge in 6th gear @ 6500 RPM. mmmmm.
all i can suggest is with the 2152 DJ kit set for stage 1 (no intake or major exhaust mods) a/f=3, needle=3, mj=dj116 (sea level, fl), it will run smooth and strong.....
  #132
Old 05-17-2012, 12:19 AM
Kawi Wawi's Avatar
Just found this thread - I may have the surge issue but I've also been playing with my TM36 jetting so it could be that causing it too... Glad I found this.
I'll try it.
  #133
Old 05-17-2012, 08:23 PM
durielk's Avatar
I got a 07 & have a stumble, is it possible that this wiring issue effects bikes in 07, or do I need to work on my jets more?
  #134
Old 06-22-2012, 06:16 PM
WHIP-N-DIP's Avatar
Cut the wire an inch from the plug, made new ground and regrounded to the screw next to it where an already existing ground was (i think on the engine) fixed the problem but kept the bike from charging my battery. Out in the middle of the Everglades, battery died, took out the ground , retwisted the wire baxk to the one in the plug and taped it and my battery sparked right back to full batt...... Is there something i did wrong? Has this happened to anyone else? Why is it draining my battery?
  #135
Old 06-22-2012, 11:57 PM
wildcard's Avatar
You made sure your grounding the ribbed box and not the existing wiring harness right ?
  #136
Old 06-23-2012, 01:01 AM
WHIP-N-DIP's Avatar
I'm not sure... i unplugged the plug next to the carb with the black and yellow wire, cut the black and yellow wire adn regrounded.
  #137
Old 06-23-2012, 01:28 AM
wildcard's Avatar
But did you ground the box or the wire that you cut that used to go to the box ?
  #138
Old 06-23-2012, 01:42 AM
WHIP-N-DIP's Avatar
couldn't get the wire out of the box, so i cut it short and regrounded that wire by itself
  #139
Old 06-23-2012, 12:47 PM
WHIP-N-DIP's Avatar
what is the ribbed box? post pics?
  #140
Old 06-24-2012, 01:17 AM
wildcard's Avatar
thats the rectifier, the part you are grounding. the budle of wires plugs into that and then you add/replace the ground coming out of the box (the yellow/black wire).
Quick Reply: Surge at 6500 rpm at highway speed
