Stuck in neutral - lost all gears
Old 08-08-2011 | 06:05 PM
miguez's Avatar
Originally Posted by Lutz
I think I just used a 1/4" drive, 6 point, deep well socket with an appropriate extension. It wasn't perfectly in-line due to frame tube interference - in which case you'll really want a 6 point socket rather than a 12 point. If you're using a 3/8" drive, I don't think it will work - there'll be too much interference with the frame tube.
Oh, and it's not a 3/8" nut...it's metric. I can't remember if this nut is an 8mm, 9mm, or 10mm. Everything is metric on this bike - if you don't have metric tools, stop and get some, or you'll inevitably end up rounding off some nuts or bolts.
Good luck.
Hey Rogers and Lutz,
Rogers, I think Lutz is right, if I recall I used a deep socket with a wobble extension, which allowed me to get to the nut while avoiding the frame. A bit of a pain, but it was doable.
Lutz, negatory, I had no idea about the new part, the one I got was the old design. By the way, I noticed on CheapCycleParts that the part shows as being 'replaced' by a new part number, this must be what that's all about. I wish I knew...
Good luck Rogers, and let us know what happened.
Old 08-17-2011 | 11:28 PM
rogers's Avatar
Sorry about the delay. Yes, the bolts are 8mm and that nut is 10mm. I had to use a wiggler and a short 8mm socket on a 1/4inch drive. Lutz, I've read your other thread and my replacement part is the older style from 2006/2007 bikes
bmwhd
06-24-2013 03:49 AM
bluvet79
07-23-2006 08:14 AM
staytru
06-24-2006 06:13 PM
sixwina
Ninja 250R
10-20-2005 08:51 PM
ninja250
Ninja 250R
08-08-2005 05:11 AM
Quick Reply: Stuck in neutral - lost all gears
