Strange Steering Sensation
Old 08-05-2009 | 04:39 PM
advtouring's Avatar
Default Strange Steering Sensation
All of a sudden there's an issue with the bike's steering. Nothing out of the ordinary on the last ride in the trails, no falling, no hitting a tree, etc just a little jumping and rough rocky riding. Now when I'm going straight and slowing down to turn left or right there's a little stiffness wanting me to stay straight. I first thought this was just the new Kenda TrkMstrs hooking up on the pavement, but it happens in the dirt. I retraced my last front-end adjustments; loosen and re-tightened the front axle, checked the tire pressure and even loosened and re-tightened the forks in the triple-tree. Still happens. I even put the front wheel between my legs and pulled hard on the bars left and right. Still happens. Any ideas on what is causing this?
Old 08-05-2009 | 04:47 PM
Sounds like your steering bearings need grease and they probably have a flat spot on them. Read my report about this a year or 2 ago. Mine was sort of a weird weave thing. I pulled the whole steering apart and cleaned and greased it. By the way there wasn't enough grease in there to........well I got no analogy but trust me it was nearly non existent. Here is the thread......you have to skip down to the pics, but its all there.
https://www.kawasakiforums.com/forum...ering+bearings
Old 08-05-2009 | 04:48 PM
Wow it was 2 years ago already.....where does the time go?
Old 08-05-2009 | 04:57 PM
Check all the cables... maybe ones really tight and restricting the movement, may need more slack in them.
Old 08-05-2009 | 05:56 PM
advtouring's Avatar
Hey Deej, I was worried about taking the bike apart to get to the carb and now you are telling me I need to take the bike apart for this. Well, I guess sooner or later I was going to have to learn by doing. I hope I have to tools and remember how to put it all back together.
BTW, the link in your thread to instructions doesn't work anymore. Do you know where I can get some instructions?
Old 08-05-2009 | 06:34 PM
That link in my post works, are you sure you are talking about the same thing? I just have some pictures and a description in there. Is the link not working at all?
Old 08-05-2009 | 06:52 PM
advtouring's Avatar
You wrote this as one of your posts...
"Here's a link I found showing how to grease the steering head.
http://www.klxzone.co.uk/images/tips...%20Guide_4.doc
It's for a klx300 but I would guess it would be similar."
That's the link that's not working for me.
Old 08-05-2009 | 07:01 PM
advtouring's Avatar
I have LubriMatic Marine Corrosion Control and Trailer Wheel Bearing Grease that I used to re-pack my boat's trailer wheel bearings. Is this ok to use on the steering bearings?
Old 08-05-2009 | 09:39 PM
That link is dead.....
Old 08-05-2009 | 09:40 PM
Originally Posted by rc
Deej,
Is this what you are referring to? That is not my link, that was from someone else.
