Strange Sound/Mechanical Problem
Old 08-06-2013 | 11:39 PM
bullonpatrol's Avatar
Default Strange Sound/Mechanical Problem
So there is a strange sound coming from the back wheel of my KLX. It sorta sounds like if you stuck a piece of paper in a fan. It occurs inconsistently, but is definitely more noticeable at higher speeds. I can't really notice a huge difference in performance.
My original thought was that it might be a bad wheel bearing, but am not 100% positive on this. Any thoughts on what might be going on, or if there is a good way to tell if it is a crappy bearing?
Old 08-07-2013 | 01:20 AM
Don't know about a bearing. Check chain tension and possible rubbing on guide and swing arm slide.
Old 08-07-2013 | 03:27 PM
ITHAPPENS's Avatar
Any chance you have it lowered? Or too much sag in rear suspension? And does it happen when hitting bumps with suspension compressed? Sounds like upper chain roller, have a look and see if it has grooves from the chain touching it.
Old 08-07-2013 | 03:55 PM
jeffzx9's Avatar
Check for a playing card stuck in the spokes.....
Old 08-07-2013 | 04:03 PM
zippets's Avatar
it is the shock splash guard rubbing on the knobby
B/F had the same problem it was loose and another time it was cracked
Old 08-07-2013 | 08:28 PM
Good call. Happens to me when carrying a passenger.
Old 08-08-2013 | 09:51 AM
zippets's Avatar
BTW what size tire you have on the back is how much air also
im still thinking your rubbing the guard
higher speeds your tire grows and if your tire is low on air pressure it would grow even taller
horizonod
01-16-2009 12:11 PM
ger87410
KLR250
06-05-2008 01:59 PM
Q500R
04-12-2008 08:52 AM
Q500R
Ninja 500R
04-11-2008 02:53 AM
BuzzAlmighty
08-13-2006 09:31 AM
Quick Reply: Strange Sound/Mechanical Problem
