Stock vs Aftermkt Air Cleaner
Old 02-07-2009 | 08:25 PM
rbarchi's Avatar
Default Stock vs Aftermkt Air Cleaner
So, I cleaned the stock aircleaner. I ask myself, what is the real air flow rate of this thing vs. aftermarket? In my signature is how my bike is set up now. Should I consider the aircleaner or just live with stock? I am a bit hesitant, because I have an old and very nice CX500 and decided to put a K&N on it.Ssince everything was stock, it ran lean. My fix was cheap (wrap 1/2 the filter with duct tape (its a barrel filter)) runs fine now. I don't want to deal with the KLX that way.
Old 02-07-2009 | 08:38 PM
ol guy's Avatar
The whole idea in the better air filter is more air flow, which requires more fuel which gives more horsepower (however slight). If you don't want to mess with jetting I wouldn't worry about the filter. jmo.
Old 02-07-2009 | 09:20 PM
KLXnation's Avatar
Banned
I'd ditch the oem and buy a good aftermarket filter. They are made of better materials, flow more air and last longer. I had a Uni on my '06 and then a Twin-Air on my '09. Both are good and do the job. For around $20 or so it's a cheap and effective mod that will be there in the future if you do decide to rejet/exhaust it as it's fine to use in an otherwise stock bike.
Old 02-07-2009 | 09:43 PM
gwalleye's Avatar
I think you'll spend around the same amount of money for an aftermarket filter vs. stock filter. Correct me if I'm wrong..
Old 02-08-2009 | 02:08 AM
tremor38's Avatar
If you plan to Rejet, get the aftermarket filter. Taping it off to richen-up the mixture would just put you back to stock filter air flow.
On another note, can we hi-jack the thread just for one post? I'd like to see a pic of your CX500. That brings back memories. I used have standard model with aftermarket air forks and cafe style faring. The forks really transformed its handling. Loved that bike.
Cptslakbladder
07-21-2012 10:36 PM
bryantjt
09-13-2006 04:28 AM
jayden
07-07-2006 09:49 PM
pimpswithmints
Joke section!
22
03-20-2006 07:11 AM
Bluebeast
10-19-2005 05:59 PM
Quick Reply: Stock vs Aftermkt Air Cleaner
