Stock pilot jet or #40
Old 06-30-2007 | 01:24 AM
acgill's Avatar
Default Stock pilot jet or #40
I ordered a #40 pilot jet with my other parts for my carb mod. Is this necessary? How many folks are changing it out and how many are staying stock?
Forgive the newbie question, but what effect will the change make?
Old 06-30-2007 | 02:07 AM
maniac's Avatar
Default RE: Stock pilot jet or #40
Well I guess that depends what else you did as far as mods. I kept the stock pilot,
stock needle, but shimed it up .030" and have the 128 main jet. I have the full muzzy
and airbox lid with snorkel removed and hole opened up. mine runs perfectly, I have
checked the spark plug from time to time and always looks nice light brown.
Old 06-30-2007 | 03:46 AM
KLXer's Avatar
1100 feet typically but have driven up to 7000 ft with no rejetting or feeling the need to
125 main
2.5 turns
NT1C 2nd Clip
enlarged slide hole
stock pilot
Both KDX & no snorkel
Fere flow exhaust
No complaints
Old 06-30-2007 | 05:58 PM
JB1's Avatar
JB1
whats your location?
I have the #40 and mine runs great
Old 06-30-2007 | 07:46 PM
+1 on the 40, my mechanic set up my bike with the 132 and 40, and no lid, runs perfect.
Old 07-01-2007 | 12:14 AM
FM_Thumper's Avatar
I don't think the difference between the 35 & the 40 is a lot. I have the 40 and 2 turns on the FS seems to be the ideal. I notice the guys that have the 35s go 2 1/2 turns out. I know that Kouba does not recommend going over 2 1/2. If you are planning other mods, I would just go with the 40, IMO.
Old 07-01-2007 | 12:33 AM
acgill's Avatar
I am in Central Arkansas, the elevation where I ride generally ranges from 1000 to 2000
Old 07-01-2007 | 12:42 AM
JB1's Avatar
JB1
Tell us more about your carb mod plans (main...needle...etc), intake and exhaust plans.
Old 07-01-2007 | 07:02 PM
acgill's Avatar
I am going with the N1TC needle and a 125 main. I am adding the KDX snorkle. I have drilled the baffle in the pipe. Probably wont go to an aftermarket exhaust until next summer.
Old 07-01-2007 | 09:02 PM
2k1w=no$'s Avatar
I found that the 35 was too small and took quite a long time to warm up. The 40 seemed good when the weather was a little cooler but when it warmed up I thought it was a little rich. I currently am using a 38 pilot at 2 1/2 turns out, but I dropped my needle to the 2nd slot and think that I might put the 40 back in.
Quick Reply: Stock pilot jet or #40
