Stock bar dimensions
Does anyone know the dimensions (width/rise/pullback) of the stock bars on a 2006? I'm shopping for a new set but it's hard to decide what size/bend to get if I don't know where I'm starting.
FWIW mine have "83" stamped on them. I'm guessing that means they are 83 cm wide?
Thanks.
Thanks.
Here's what I measured some time ago on the oem's before I got Renthal's.
Accuracy not guaranteed...
Width (tip to tip):
785mm
Height (from bottom of bar at clamp to bottom of bar at outside end of grip--vertical height):
50mm
Rise (length of slope between clamp area and where bend starts for grip area):
35mm
Clamp area (length of straight bar in clamp area):
150mm. Clamps are 110mm outside to outside.
Sweep (the amount of bend in the grips towards the rear of the bike):
90mm
Ron
Width (tip to tip):
785mm
50mm
35mm
90mm
Ron
2007, 250, bar, bars, bend, demensions, dimensions, kawasaki, klx, measurements, renthal, stock, width
