Still Ticking
#41
My rad shroud also vibrates against the tank... I'll check that again too but i have a bad feeling that's not the issue...
Alright, so from what i'm reading when i do a search, i can also adjust the tensioner manually by taking out the 12mm bolt at the tensioner and adjusting it one "click" with a screw driver?
I wanted to learn to tinker with the bike eventually but i bought it new.. so i wasn't expecting to have to learn this early!
Maybe i'll bring it to the shop... booooo
#42
a little background since I got the bike it was bone stock and I was pretty unhappy with the power alright, I didn't like the fact that between shifts the revs would drop off so quickly, and it felt like it would bog trying to get the power back up into a useable range, now with the mods, she dops off no more than 1000rpm, easy shifting, if I get on it, and work it hard, it will drop less than 500rpms, accelerates so much better, I ride mostly on road or gravel/dirt road, have not been on bush trail yet with it, anyways after a few mods and dollars, I couldn't be happier with this KLX, I have had many a bikes in my time, had my license since 16 and I am now 47. Started on dirt, then enduro, then street form 400-750cc, then to a cruiser yamaha vstar, now this, and I tell ya, I am having more fun with this than all my previous rides, it brings back the kid in me and puts a smile on my face everytime I grab a handfull of throttle with the sound of my Q4 pipe.
dynojet kit, airbox lid removed, AIS crap removed, and FMF Q4 pipe, shes a blast to ride.
thanks to everyone on this forum for the input, the information shared here is invaluable.
Ride safe, cheers Greg.
#43
Thanks macgregor77!
The only difference in symptoms in my case is that i haven't heard/noticed any noise on a cold start. I'll check for that tonight. I think i'll go ahead and try the manual adjustment.
macgregor77 is right - this site is invaluable, especially to newbs.
#44
I'm currently in frequent contact with Mark Krieger of Kreiger Tensioners. He wants to make a manual tensioner for the KLX250/300. I've taken pics, various dimensional measurements, and a "rubbing" image of the tensioner mounting surface on the cylinder head. There are a couple of oddities with the tensioner on our model, but he feels they can be overcome. After he receives the exact pattern image I sent today, he will have a better idea of design and fitment.
#45
NOTE*** initially it was only making the clacking or vibration sound at the 5000-6000 rpm range, after about 1,000kms later it started to develop at startup when cold loud and would taper off, but basically it became like a rattle or clack all through the power range, seeing I knew the valves were in spec and this was somethign that progressed and gradually got worst, then I figured it very well could be the tensioner on the chain, but wasn't really sure to tell you the truth, but I was so "surprised" and "happy" to find out thats what it was, a 5 minute fix, and she runs smooth as heck now, try it, you go nothing to lose, you will be glad you did it, trust me on that.
UPDATE*** a co-worker has the very same bike, with 1000 less KMS and he has developed the very same symptom, he sent me an e-mail yesterday, asking next time I bring my bike to work can I let him know, he wants to hear mine, as he states his has developed some top end noise and thinks it maybe his valve train ;-), wait till I tell him that I can fix it in the parking lot at work in 5 mins, yup, I am going to make him a believer too, Ride safe everyone, these KLX's rock!.....cheers MacGregor.
#46
You actually leave the 12mm bolt alone. You loosen the 2x 8mm bolts until you hear 1x click then re-tighten. Another way is to remove the 12mm bolt and spring, stick a small long screw driver down into the spring hole and force the tensenioner to click. Either method works the same.
#47
You loosen 1x 8mm bolt and the other 8mm you very slowly loosen till you hear the click sound (1x click). Then just re-tighten the bolts. As for torque, I forgot the specs, but it is not much. Just don't put you weight into tightening it, just the weight of your arm on a 1/4 inch rachet is enough torque.
#48
![Big Grin](https://www.kawasakiforums.com/forum/images/smilies/biggrin.gif)
#49
Awsome, thanks, I will try tonight when I get home, my bike is ticking in the 5-6 thousand rpm range but it's not ticking on start up yet, hopefully there will be another success story for this fix tomorrow..
SDRRider
07-06-2006 09:00 PM
