Still Ticking
I had this noise, and fixed it by manually forcing the tensioner one click. That was more than 1000km ago, and it is still quiet and runs great. Not that is WILL fix your bike, but it is worth a try, I think. If the spring is getting weak, it will take a long time to make that next click, and it will drive you crazy. And it's free to try, and you can always take it out and reset it if you don't like it. Just my thoughts.
Ah, this again. You mostly likely have the same issue my KLX had. I finally found out that the cam chain was out of service. It doesn't take much, only like a 1/16" stretch and the cam chain is done.
Heres the little write up I did.
https://www.kawasakiforums.com/forum...t=timing+chain
For now, I am just going to fix the leak, check the tensioner one more time, and just keep the oil changed. I may manually make it go to the next click. I will keep you guys posted. If its starts doing it at idle once warmed up, thats when I will start tearing into her.
I can't believe it, but moving the tensioner to the next click fixed it. It has no ticking at all at 5-6k, and nothing at cold start up. Which amazes me considering how hard it was ticking. Thanks guys for everything!!
As for abuse, I will never know. I think my KLX had only one oil change since I got it at 1,800miles. And since the last owner said he used 10w-40 but didn't know what kind, I promptly changed the oil with the correct lube shortly after.
Forcing the tensioner out a click every 500miles probably didn't help either. In about 400~500miles the clanking would come back and get really annoying, sometimes embarssing out in public. But after all the work I did, I'm very glad to report a clean 500mile drive and still not a single clank. The KLX engine runs nice and smooth from idle to 8,500 rpms.
