Stiffer fork and shock springs for an '09
Who makes em? Where do I get them? I'm having a hard time finding anything for an '09. '07 and before, I can find anything but that does me no good. I'm a big, fat guy and I need to stiffen this up some.
Part of the problem with springs is knowing what you have. If the attachment goes through fine you'll find a zip of an Excel spring rate calculator I recently made. With calipers and the Excel file you can determine the spring you have to find something different.
+1 ... no secret I'm a happy Moto-Pro customer.
You can also check out Race-Tech. These two are among the best known, but lots of other good alternatives ... Google away.
I bought .44 kg/mm fork springs and a .61 kg/mm shock spring from Cogent and it really helped the suspension. If you only want to do one end do the fork springs.
http://motocd.com/
Doug
Front Fork Pre load
Excuse my ignorance but is it not possible to adjust the pre load on the 09 KLXs 250 front forks. I weigh 187lb and have about 1 1/2 inches of static sag. Also is there a replacement cap available for the top of the forks that has the air bleed screw in it.
You can put spacers in the top of the forks to give you a little "preload". But you are heavier than me and I rather like my .46 springs... But spacers would be a temporary solution.
I have only seen valves that replace the brass screws.
