Stator Rewind
I want to beef-up my electical system enough to handle a heated vest. Does anybody know of somewhere that professionally rewinds stators and possibly has had experience rewinding the KLX250/300 stator? I'm already familiar with the tech article at Planet KLX, but I simply don't have the time or space to do the work myself.
I wrote an email to Baha Designs' tech department to ask if they would be willing to entertain the job...still waiting for a reply. If any of you know somewhere else that does that type of work, I would appreciate knowing about it.
Thanks.
Thanks.
sorry no help from me bro.... let us know if you find anything out. Heated vest? never herd of it before... good idea... kinda like the heated thumb throttle on a snowmobile.
ORIGINAL: EMS_0525
I'm pretty sure the KLX will handle heated grips in stock state, but the electic vest would be pushing things a bit far without rewinding the stator. The are two empty poles on that son-of-a-gun that are just begging to be wound and put to use!
I watched a special on the discovery channel on cold weather survival and it showed that keeping the core temperature up also served to better warm your extremeties. They had a guy in a climate controlled chamber with variable wind gusts or sustained wind at minus 40 degrees. He had to do dexterity tests like assembling a bunch of 1/8" nuts and bolts, do brain teasers, and write sentences. With gloves he couldn't do the small stuff, w/out gloves it was only a matter of minutes before his fingers were too stiff to do any of it very well. With the heated vest his hands never even got cold and his brain function didn't decrease either. They showed a thermal image and his hands were warmer than the test monitor who had just barely taken his hand out of his glove, much warmer. In essence a heated vest will do more for keeping you comfortable than heated grips.
ORIGINAL: bryantjt
Guess I'm back to square one with the Hot Grips and layered clothing...oh well[8D]
Hay tremor, what exactly did you find out? It's hard to believe that there's not enough extra capacity in the system even with a stator rewind to power a vest comfortably. A guy at work loaned me an electric vest that he used to ride with. He said it's the best thing he's found to stay warm. I've been reluctant to use it yet though for the same concerns you have. He rode a 1 liter street bike so there wasn't an issue with his. It doesnt say on the vest how many watts it pulls. Does anyone know how many watts the KLX can handle?
Hi there.
I have been running a heated vest and grips from day one with no ill effect.bought the bike in jan.now have 8000km's on the beast.
I have replaced the rear tail light with a led bulb and I never run both at the same time unless I am at cruising speed to keep the rpms up as not to drain the battery.
[IMG]local://upfiles/1301/FAA9AA6983AE4AB29706FEA5CD31069B.jpg[/IMG]
What is the power consumption of the vest?
I think the stock unit can supply around 200w.
Add it all up.
Lights etc and see what is left.
Indicators and the brake light are not on very often and there's 60w or so, so they can almost be not included in the calculations.
The battery will help out when they are on if needed.
Add it all up.
I think you give this bike too much credit. The stock stator puts out a whopping 90W. After the rewind, its capacity is raised to 110W.
The current draw of the vests is anywhere from 38 to 54 watts, depending upon manufacturer. The Gerbing is the warmest one made and it draws 54W when running full blast. In Japan, the head and tail lights are hard-wired on, maybe you can switch them off in Aus? I'm told the heal/tail light combo comsumes about 60W. That doesn't leave a whole lot of headroom, if any. I still need to put a meter on this beast to check the actual current draw through.
ORIGINAL: neilaction
Add it all up.
Add it all up.
I don't know where you're located, but in Japan the head and tail light cannot be turned off. I could wire in a switch, but if I get caught it would be a hefty fine.
What brand of vest do you use?
***Update***
I may have misread your post. I think you meant that you don't run the grips and vest at the same. I was locked onto the tail light for some goofy reason.
***Update***
ORIGINAL: speed2101
Hi there.
Hi there.
