Starter Jet Drilling - Verify Location Please
Finally starting my long list of upgrades to my 2009 KLX250S.........
Need to verify the location of the starter/enrichment jet to drill it out to .018"
Can anyone verify if the below is correct........sure don't want to drill the wrong thing.
Thanks...
Thanks...
Thank You....
Sure was a lot of crud in the carb......suspect the previous owner left gas in the bowls many times during non-use and it dried out, leaving a lot of residue.
Bike is a 2009 and only had 168 miles on it when I bought it.
Took all the jets out and soaking everything good to clean it out.
Huge box of goodies to install.
I just drilled mine today. I hope it starts better in the morning. I have a question how long or (depth) is the jet? I found a .018 bit at the hobby lobby here in town. The bit was only about an inch and a half long. I didn't feel it bottom out on anything and hope I got through the jet.
I did feel resistance when I was drilling. I don't think I felt it bottom out. The bit did go cleanly through a couple times after I finished the first drilling.
On our KLX this seems to fix most of those with cold start issues, but there seems be one or maybe more additional issues on some bikes...like the KACR or such. The off-road-only KLX300 doesn't seem to have as much problem with cold start and that's just with a kickstart...well, at least no more problems than many 4-stroke dirt bikes when cold starting.
