star shifter
star shifter
I have a 07' and it now has 1300 miles on it and lately when I've been riding offroad it keeps popping out of gear I changed the oil but it was still doing it. I searched around on here but didn't know if the anybody knew if the 09's star was better or would fit on the 07 to solve this problem.
RE: star shifter
ORIGINAL: jaylaudeman
RE: star shifter
It's a well known issue with these machines since the mid-90's KLX300...
It's not that hard to modify your own star with a grinder...
Check these threads.
Oh, also try switching to synthetic - I found it helped the shifting...
Double snorkel & shift star fix installed
and here
Shift star dilemma solved (sort of)
Ooops, I guess the images are broken now but the text is in tact...
Some supporting images here: http://picasaweb.google.com/KawiWawi/20060808StarProb
and here
RE: star shifter
I think its been doing it from 2nd to neutral butI think its also done it from 3rd too.I know sometimes its from not getting it engauged all the way but it seems like more than that because some I'll come out of a corner in first get on it hard then go up to 2nd nail the throttle and it will engauge for a second or two then pop out of gear. Thats why I was thinking maybe it was the clutch.
I found the new links to the old threads through the search function (which, by the way seems to work better than the old search - it actually works when searching by user name).
https://www.kawasakiforums.com/forum...ead.php?t=5717
https://www.kawasakiforums.com/forum...ead.php?t=5832
