Staintune Pipe
Old 04-09-2008 | 01:17 PM
chris72a's Avatar
Default Staintune Pipe
Hi All,
Got my staintune pipe today, took it for a quick ride and what a difference, doesn't seem to be any flat spots or anything, a bit more decel popping but feels like lots more power, or could just be my imagination, I'll post some pics when I find my camera. Jetting is still stock, apparently the staintune pipes don't require you to rejet.
Cheers
Chris.
Old 04-09-2008 | 01:25 PM
Default RE: Staintune Pipe
um..... yea... im thinking you should rejet, if its more powerful, its flowing more than stock, which means its more lean than stock.....
Old 04-09-2008 | 05:33 PM
captaintrps's Avatar
ORIGINAL: EMS_0525
Lean = popping on decel, I'll bet your plug is white on the electrode ceramic. You could try tweaking your air/fuel screw a half turn out, but you should probably just do it right and rejet.
Do you have a better than stock air filter? If so, then you don't have a choice.
Trial and error - I'd try one size up on the pilot jet, one notch down on the needle and one size up on the main...I think I have that right. 1.5 turns out on the air/fuel screw.
It's been a long winter.
Old 04-10-2008 | 10:30 AM
tremor38's Avatar
Staintune is assuming that you are not taking off the air box lid or enlarging the opening in that lid.Withoutgiving the bike moreairflow at the input and rejetting, your power improvement will be marginal at best...'justsayin'
Then again, if you are happywith that.... To spend$800.00 Aus on a beautiful pipe and not realize it's full potentaldoesn't make a wholelot of sense, IMHO. [8D]
ORIGINAL: chris72a
Hi All,
Cheers
Chris.
Old 04-10-2008 | 11:31 AM
chris72a's Avatar
Cheers Guys, I'm taking my bike to a kawa mech, to get some jetting done, he's renowned as being one of the best so I will put the bike in his hands and see what he can do.
Cheers
CHris.
Old 04-10-2008 | 11:34 AM
Good.... doing it right. You will be happy, it will have more power.
Old 04-10-2008 | 11:51 AM
chris72a's Avatar
Hey Tremor,
Na did a deal with a guy that knows someone who knows someone at Staintune so got it a lot cheaper, I was Happy
Old 04-10-2008 | 12:37 PM
ClassicMe's Avatar
I had my Staintune full system and 300cc bore kitinstalled by a Kawi dealer, they attempted to re-jet the carb, unfortunately,at low speeds the bike was almost unridable when I got it back. They seemingly had know idea howto tune the bike.It wasn't until I got aTM34 from Bill, that it started performing well.
-Justin
Old 04-11-2008 | 12:26 PM
MaverickAus's Avatar
I got mine second hand with the 300 cylinder for $500, not bad for a $940 system (new price) and a $600+ cylinder (new price).
The 300 cylinder will be shortly winging it's way to Bill Blue for boring out and a sleeve fitted to make it a 331 [sm=bling.gif] [sm=nxsmile.gif] [sm=wootwoot.gif][sm=gears.gif] [sm=drooldude.gif]
8cuttlefish8
11-05-2009 08:14 AM
MaverickAus
03-12-2007 10:59 AM
zx6chic
12-21-2005 04:48 AM
MK1gti20v
09-14-2005 06:47 AM
ryninger
07-20-2005 04:06 AM
Quick Reply: Staintune Pipe
