Speed Calculator
Speed Calculator
I was curious about how the speed of the KLX250 was affected by gearing, tire sizing, etc. I know about gearing commander but wanted to work out the calculations myself.
I created a google sheet if anyone would like use it.
Speed Sheet
I have a GPS and eventually want to correlate my indicated speed to my GPS.
Long term, maybe add actual data from users to help others when a speed issue arises.
Any thoughts out there?
Speed Sheet
i know that the stock gearing is a little low for the power output of the engine
i know that i went taller and had the bike actually hit the red line 10500 rpms
that was using 14t F / 48t R i think i was going 10500 @ 70
stock was allmost 14t F / 42t R 70 @ 7000 topped out @ 8200 rpms
im thinking if someone went 14t F / 44t R they should be able to hit well over 90 (theory)
but i believe i heard add 300 rpms per tooth in the rear
Looks pretty similar to the Gearing Commander
Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
So is you are going 70 MPH with stock rear and the engine is at 7000RPM. Then if you change out to a 45 (3 teeth larger) your RPM will be 7000 times 6.9% (2.3% x 3 teeth) equals 7483 rpm.
Yeah, zippets had it backwards. Low gearing is like first gear. Tall is like 6th.
I find the stock 14/42 gearing slightly too tall for the trail but want a taller gearing for the highway so I'm leaving it alone. Why on earth they didn't make 6th gear much taller I'll never know. We have a close ratio transmission but at least there are 6 gears.
It strikes me that Kawasaki did the reverse for the 09 and later, compared to 06-07: they made 5 and 6 closer, aggravating the situation. Apparently they thought not so many customers would have agreed with my views...
