spark arrestors
RE: spark arrestors
Thanks for the comments. It sounds perfect. Inbetween aftermarket and stock. It has a deep tone without the raspy putt putt sound. I plugged the baffle with a freeze plug and drilled four 1/2" holes in it. It was still poppy sounding until I welded the tip on. There is a 1.5" hole at the end of the pipe inside the 2.25" tip.
RE: spark arrestors
ORIGINAL: vurtle
here's a pic
[IMG]local://upfiles/3707/6706D68DCEC241F1BD6AEC8713A9150F.jpg[/IMG]
here's a pic
Thanks for the link!!!
RE: spark arrestors
Does anybody make a down-turnedtip for the Big Gun Evo X? Most of the exhaust tips I've seen go straight back.
Someone else who did a custom exhaust said that orienting the exhaust towards the ground quiets it down a bit without causing any significant restrictions. If that's true, it might be worth investigating.
