So what am I doing incorrectly? Speed sensor issue
Okay, have the speed sensor back apart. A couple of questions:
1. The parts schematic says the inner hub is part number 21192, but I can't find any hub that looks like this one using that part number. They are all black and have much more prominent tangs. As you can see, this one appears pretty worn.
2. Is there supposed to be anything in the hole at the top of the speed sensor hub? You can see the sort of square hole inside the hub at the top in the picture.
3. Don't mind replacing the sensor magnet, but at $35 or so, I don't want to spend it if the speed sensor hub is broken.
https://www.kawasaki.com/Parts
Hard to tell from the picture if that top hole is bent or if that's normal to the design.
Installed the new sensor and it works correctly now.
Only question left is how the part worked when I was test riding the bike and for the first weeks after I got it home. No way it should have worked at all.
