Snorkel Removal or better air filter?
Hello All,
Snorkel removal or a better breathing air filter? Is one approach better than the other or can both be done without rejetting the carb? I have an '07 with stock exhaust. I ride at an elevation of 1250 ft. Will either one or both make any noticable change. At some point I'm sure I will give in and go for the complete upgrade of air intake and exhaust. But for now I was just wondering if I could do a free mod without leaning it out to much. Thanks for the help. Oh, also do you just pull off the snorkel from the top plate or do you need to cut it off?
Its already lean from the factory..... then add in 1250ft...... its even leaner
take off the snorkel add in after market exhaust you get the air moving or more flow.......
fuel man, you need fuel!
Wedge, higher altitude will make it richer. Same fuel coming in, but less oxygen in the air. Todd, 1250 ft is not enough to make it too rich though. You may be ok with a hi flow filter. I don't think you'll see much power difference only changing the filter. You've got to pipe and re-jet along with the new filter to feel any difference. I'd leave it alone untill you get a pipe.
PS the snorkel doesn't have to be cut out, it will pull out. I run mine with the lid on and snorkel removed.
right! forgot about that (higher alt not enough air)it get rich and bogs more
I put the KDX snorkle in. with all the jetting mods. when I read the other post a bell went off
Dont remove the snorkle! If you do any kind of water crossing or riding in any mud. Instead goto your local kawi dealer and get a snorkle off a kdx220. It fits and offers twice the amount of air to come in. You have to rejet though because your bike is going to be lean.
Steve
Steve
what is the point in doing just this? If you ware wanting more power, just do the free mods. BTW, I drilled the exhaust through the two baffles ,and it really was not any louder.... of course I did end up getting an HMF. that let out a fair amount of horsey's bot is not a "free mod" ....
Both. I have an TwinAir filter AND I pulled the snorkel... but +1 on rejetting. I'm only a couple hundred feet ASL and it is unbarably lean from the factory. Don't pull the snorkel or change filters until you rejet.
I finally rejetted over the winter when I put the aftermarket exhaust on. Its like a new bike now.
