skips a beat
Old 07-22-2009 | 03:08 PM
finzel's Avatar
Question skips a beat
has any one sloved the intremittent miss problem yet? 2007 klx 250s. has 331 kit o/s header drz 400 muffler.runs strong . just skips a beat. dave
Old 07-23-2009 | 12:18 AM
WestOzKLX's Avatar
Mine runs fine??
neilaction's Avatar
What problem?
Is this a know/common thing?
Check plug and associated wiring. Sounds electrical to me.
BTW, have you got a stock DEZ muffler on your bike?
Never heard of that before.
Pics please.
Old 07-23-2009 | 02:31 PM
finzel's Avatar
Default skips
had to remove about 8" from pipe,reweld end pice to slide over header.mounts toframe and to pass, foot peg,after removing the peg. good sound and power, dave
Old 07-24-2009 | 04:48 AM
je2000's Avatar
What problem?
Pics please.
Mine does it. Haven't been able to figure out what it is. I'm in the process of converting everything back to stock. I took it into the dealer and they said it was my jetting that was off. I'm going to take it back in (still under warranty) and demand to have the stock bike fixed like I should've done a year ago. Do a search for highway stutter and you'll see my threads bitching about it.
Old 07-24-2009 | 06:51 AM
DigiSnapMark's Avatar
Mine does it too... bone stock 07. They are single cycle dropouts, happening when on the main jet, pretty much at all throttle settings. It's annoying, but so far, not critical.
Old 07-24-2009 | 07:42 AM
gerrynolan's Avatar
I believe several people fixed this problem by fixing a wire connection under the seat. Not sure what to search for but it's definitely here some where. Good Luck. PS, Jets won't be intermittent.
Old 07-24-2009 | 06:56 PM
Beardoge's Avatar
My 07 does it too, mostly when you run it hard at higher RPM, can't figure out what is causing it but if the son of a bitch quits and leaves me stranded it's going into the closest ravine or hole and will be reported stolen.
Old 07-24-2009 | 08:55 PM
2k1w=no$'s Avatar
A lean condition in jetting will feel just like a miss. You mostly feel it on the road when staying at a certain rpm.
Old 07-24-2009 | 10:24 PM
revtor's Avatar
Mine's got a miss every now and again when I'm at a steady 3.5-4k RPM. . Only in that RPM range though. Also has quite a popping/backfire if I chop the throttle closed at high RPM. Lean? seems like it could be. I'll raise my needle a clip and see what changes. Runs great though, starts easy and pulls hard up to about 8500.
340cc, FCR35, KLX300 exhaust/FSW header.
Love my 340! Best bike EVAR! hahaha
~steve
~Steve
WHIP-N-DIP
06-16-2012 03:00 AM
TUCAZ520
06-22-2008 11:14 PM
mfdanna
01-06-2008 04:52 PM
ktn
06-05-2007 04:37 PM
jared
Ninja 250R
07-16-2006 11:13 AM
Quick Reply: skips a beat
