Signal Minder Running lights...
Okay so now I have conflicting reports.... Guy at dealership (who owned same bike) said that LED's are a direct fit swap, just tie into existing wires and go. Tremor's comment (and some bikes are like this, reflects the kind of system where the lights ground across each other and if you dont isolate the indicator light by creating an independent ground and using diodes for input from either side then you get 4 way LED flashers. I'd really LOVE for even just one guy on the forum to say he put in LED's and didn't have to do the mod.. or found he did. Any takers?
There are also documented posts of the current cross-feed through the indicator light (06/07, this forum).
I'm not sure if the 09 has a solid state flasher, but if it does, and you own an 09, you're probably good to go.
![Stick Out Tongue](https://www.kawasakiforums.com/forum/images/smilies/tongue.gif)
![Confused](https://www.kawasakiforums.com/forum/images/smilies/confused.gif)
Hadn't thought of the LED's coming with load compensators. That's a possibility, maybe dealership guy bought lights that had it and didn't think of it. Personally, I'd rather do all the work to make it right, installing LED and not taking advantage of the power savings doesn't make much sense to me. Now I gotta figure out what kind of Diode's to use.
![Smile](https://www.kawasakiforums.com/forum/images/smilies/smile.gif)
150, conversion, indicator, installing, kawasaki, klr, led, light, minder, running, signal, signalminder, signals, tracker, turn
