Shut of while riding. Will not crank until I push the bike around a bit
Old 10-05-2018 | 05:26 PM
IKLXG250's Avatar
Default Shut of while riding. Will not crank until I push the bike around a bit
So i was riding home from work and my bike completely shut off on the highway going 70mph. At firdt i thought a co-worker had turned my pea **** to off but that wasnt the case. It would not crank while i was on the shoulder, eventually it started up again just to turn off on me a couple more miles down the road again. When it would idle way it was idling lower than usual and shut off as son as i let off the gas.
Anobody have any suggestions on what my problem could be?
Old 10-05-2018 | 06:24 PM
Brewster's Avatar
Clogged gas tank vent??
Ride on
Brewster
Old 10-05-2018 | 07:56 PM
Check the carb vent lines. Sometimes they get pinched or melted by exhaust pipe.
Old 10-05-2018 | 09:01 PM
dp19's Avatar
If it won't crank you should check for electrical issues, possibly a broken/shorted kill switch.
Old 10-05-2018 | 09:58 PM
^ good point.
IKLXG, can you clarify "not crank" please? Does that mean the starter would not turn the motor over? Or does it mean the motor was turning over, but not starting?
Old 10-05-2018 | 10:35 PM
durielk's Avatar
Yea, and have you had the bike swimming lately?
Old 10-06-2018 | 03:17 PM
IKLXG250's Avatar
Ride on
Brewster
where would I be able to find the gas vent??
Old 10-06-2018 | 03:19 PM
IKLXG250's Avatar
Originally Posted by IDRIDR
^ good point.
When it shuts down the display stays on, but starter will not turn over until I rock the bike back and forth quite a bit. When I do get the bike to turn on it idles way lower than normal
Old 10-06-2018 | 03:23 PM
IKLXG250's Avatar
carb vent lines look good but I have smelled burned plastic a time or two but couldn’t find where it was coming from. I’ll have to check it out
Old 10-06-2018 | 03:24 PM
IKLXG250's Avatar
Never been swimming that I know of. I just purchased the bike second hand 3 months ago with 9,000 miles for $1,100 so I don’t mind fixing a couple of things here and there
Quick Reply: Shut of while riding. Will not crank until I push the bike around a bit
