Show me your toolkit
I remember the first day home with my bike looking at the stock toolkit, I couldn't help but chuckle when I saw those pliers, REALLY!?!
Since then I've wanted to do two things; find a better place to stow my toolkit and replace the tools with better/fewer ones. I could have screwed the stock toolkit right into my Pro Moto rack but then I would be losing storage space on the rack. I didn't like that idea. I tried to wedge some tools above the instrument panel and that didn't work. So I decided the best place was under my rack above the taillight. It would be out of the way but convenient. The obvious problem was what to put there since the stock toolkit was too big.
Well yesterday at OfficeMax I saw a neoprene eReader case on clearance. It was the right dimensions and slim enough to squeeze between the rack and the bike. I cut two small holes and used oversized washers with the stock toolkit bolts and screwed it in. It fits great with easy side access to my tools.
Which leads me to my next question, what's in your toolkit. One thing I've learned is we all have different tool needs. What might be right for one guy would never work for the next.
So when building my toolkit I did so with a minimalistic approach to it. My daily commute is only a few miles so there is nothing on a daily basis I couldn't handle with my kit. Whereas if I was going camping I would bring a lot more tools with me.
Obviously I replaced a lot of the stock tools with an 8" adjustable wrench and a mulit-purpose tool. Most notably missing is anything to change a tire. I'm still thinking about that.
But I was curious what others have that I should consider adding. Eventually I'll have two toolkits, one for daily use and one for road trips and such.
Brein,
I'm still working on my "final" tool kit. I really like a front fender bag for the longer trips. The end of this post shows something I found elsewhere and am working on. https://www.kawasakiforums.com/forum...e2/#post461346
In know people hate the "use the search" response, but if you do, you'll find some very interesting tool kits on here.
Stockton Tool Co (Cyclegear brand) makes a couple small multitools that I bring along depending on the riding conditions. They can usually be had for under $10.
STOCKTON TOOL COMPANY Universal Parts & Accessories - 15-in-1 Multi Tool - Cycle Gear
STOCKTON TOOL COMPANY Universal Parts & Accessories - Mini Ratchet Kit - Cycle Gear
A $40 annual membership in the AMA includes roadside assistance, which includes towing for your 4 wheeled vehicles too!
I bought the AMA card so I could ride certain events where membership was required, and other events where AMA member's entry fees are discounted. That card easily paid for itself last year. On joining they send you a $10 bike bandit card, I saved another $30 on entry fees for a couple DS events, and then the wife's minivan broke down and needed a tow.
i do a lot of long distance trips...and, i really wanted the 200 miles towing...
Where did you get that spark plug container? I pulled mine out from the stock toolkit bag and found the threads and been damaged from continuously rubbing against the tools.
