This shouldn't break
#32
What's a bad idea?...making your own stud? Done properly, there's no issue in using a decent bolt to make a stud for an application like this. I guarantee that the OEM stud material ain't that great. In fact I'd bet if you go get a grade 8 stud or bolt to do this fix, you might end up stripping out the fork leg and/or cracking the place where it threads into the fork leg. I'd rather have a mild steel stud or bolt made into a stud. Much better to sacrifice a bolt/stud than a fork leg. Put some red loctite on the threads that go into the fork leg so they seat into the fork leg. Don't worry...those threads will still come loose when you need them to if there's another snapped stud. Red loctite is strong, but it's not welding.
#33
#35
True...but this is an issue occasionally on the KLX...and other similar forks. Just nice to know there are options to the fix.
#38
Mike
#39
One of these would work.
http://www.sears.com/shc/s/p_10153_12605_00904458000P
or just grab it with vise grips. Shouldnt be too tight. One of the studs was actully broke when i bought my bike...lol. So i told them to just take them all out and put bolts in. Under warranty. My dad is a mechanic so i have access to $30K in tools...
#40
I was able to take out broken stud with vice grips. Backed right out.
And I would advise against using straight up bolts.. That is aluminum they're going in. If you keep taking them out and putting them in you risk stripping the holes... Then you will need to drill/tap the forks, or replace them all together..
If you cant find the studs use those bolts, snug them down, and pop the heads off with a dremel, then use the nuts..
