Should petcock turn fuel off?
2009 KLX250S
Weird question I know, but I've been round and round with different petcocks (Suzuki I'm looking at you!)
Here's the situation, I need to change the fuel line from the petcock to the carb also I am adding a new inline filter.
So I turn the petcock to off, pull the line and fuel just keeps coming out. If I turn it to on or res, then it REALLY flows!
So now when everything is back together I have a constant drip of fuel from the hose on the bottom of the carb bowl.
This can't be normal, right?
Thanks
CB
Thanks
CB
This is not normal. Two problems you may have. A failed petcock, obviously, and float problem in the carb. This may be a non-sealing needle in the seat, a stuck float (tap on the carb bowl somewhat gently with the plastic handle of a screwdriver to see if it will unstick), or a mis-adjusted float.
