Should I go back to stock pilot jet? need help
#41
I just bought a new float needle ..no harm in having a spare or maybe it will fix the issue.
#42
got it found it.
wow so many times I've looked through this pdf manual using the search terms "carb" as well as manually scrolling ...and was never successful
#44
Cool. That happens.
#45
Which one is missing?
#46
could be the reason..
but I believe most of the gas is because
1) I may do a wheelie, drive through a park with rumble road, or do a power slide (and dip the bike low) ...causing gas to get into the tank overflow tubes (which sometimes forget to unplug since I plug them up after letting bike air out to limit smell in my garage)
2) prob something wrong with the float needle getting tiny small drips from the float bowl ..
3) maybe excess fuel in the carb (throttle port?) or whatever its called ..because Im a newb idk...
#49
only thing is I dont see any gas comin out...
#50
not seeing your point ... but the bike was like that when I bought it.
I ordered a new one from Kawasaki. should be here by Monday.
WHIP-N-DIP
08-14-2012 11:45 PM
chuck2302
05-14-2008 12:14 AM
