Shorty Levers
Yes, they will. I have them on my '09-10 with no problems, only smiles.
Just trail ride and fall off just right (as I seem to have a talent to do)... the tip will snap right off, or if bent it will snap when you try to straighten it, usually leaving a perfect 2-3 finger clutch lever. With enough time you may get a brake lever that way too.
Just remember to put on bark busters immediately after getting your levers - and file the lever end to look good too - wouldn't want you to stick it in yourself by mistake.
Seems to me if you're having fitting issues, it would be the fault of the handguards, not the stock levers. My Maier handguards fit nicely over the stock levers. No problem!
