Shorty Levers
Old 05-29-2012 | 04:14 PM
Websurfing101's Avatar
Default Shorty Levers
Looking for shorty clutch and break levers. Any ideas that won't break the bank. Don't want to saw the ends off. Thanks
Old 05-29-2012 | 04:31 PM
Brieninsac's Avatar
I was at the dealer on Friday ordering a new clutch lever. Apparently there aren't a whole lot of options for after market levers for the KLX... at least that I've seen. So I bought an OEM one for $5. Until I can find something better I'll stick with that.
Old 05-29-2012 | 04:37 PM
cegusman's Avatar
wheelingcyclesupply.com has them $10-$12 each if i remember
Old 05-29-2012 | 04:40 PM
Brien, that is the same problem I am having. Trying to find the shorter levers? I keep bending the clutch lever when I dump the bike. I want to put on some hand guards and add the shorter levers for the fitting issues.
ns503's Avatar
DRC levers from Wheeling.
http://www.wheelingcyclesupply.com/s...11/index.shtml
I got a pair last year. Unfortunately, they're still on the shelf due to a way-too-long Other-Things-That-Need-Done-Around-Here list...
Old 05-29-2012 | 04:46 PM
Sweet, thanks ns503, that is what I am looking for!
Old 05-29-2012 | 05:01 PM
A hacksaw and a file or grinding wheel. I have the original levers from '06 on mine that have been cut down, and they work like new. Short levers and bark busters equal the end of broken/bent levers except in the most unusual circumstances.
Old 05-29-2012 | 05:31 PM
ns503's Avatar
Well, ya, you could do the hacksaw thing - I like having ***** on the ends of my levers though.
Old 05-29-2012 | 05:49 PM
Brieninsac's Avatar
Wheeling Cycle Supply - KLX250 Specials | Accessories
It says for '08 model. Any idea if they will fit the '09-10 and '12 models too?
Old 05-29-2012 | 05:50 PM
A couple applications of heat shrink tubing. First a smaller diameter one, about 1/2+" extra folded back over itself. Then next diameter up over both without any extra length. The end result is a nice set of comfortable ***** on the ends.
Redpillar gives some better instructions and pics around here somewhere.
