shorter travel on the clutch lever, please
Old 12-12-2018 | 05:09 PM
Verwah's Avatar
I have found that the stock KLX cable has enough adjustment in it to get a short throw action. I only work the lever with one or two fingers and the others are around the grip at all times. Just a little dab and it works great. At speed no clutch is necessary for up-shifts at all if you get a feel for it.
Maybe the condition of the cable and clutch disks has something to do with that?
RaceGass's trick is pretty clever though. If my cable were a little too stretched out, I might try that.
Old 12-12-2018 | 09:53 PM
RaceGass's Avatar
Moose racing version. Common thread being either the lever pivot bolt being closer to the bars for a softer pull/higher ratio or the cable end located closer to the pivot point
ronopolis
08-18-2016 02:07 AM
kennysupermoto
07-13-2013 02:52 PM
thehunterman
06-25-2013 02:31 AM
nuzzy
Ninja 500R
02-07-2012 02:03 AM
azklx250s
06-02-2008 02:24 PM
Quick Reply: shorter travel on the clutch lever, please
