Shocks
Old 11-19-2006, 05:33 PM
DirtSurfer's Avatar
Default RE: Shocks
11 inches and 8 inches respectively.. I set the sag soley with the spring compresson nuts. I set my dampening on feel, based on how it rides/lands and I've been steadly tweeking both rebound and compression down to where they are now.
Thats why its seems confussing that he went the other way on the rebound adjustment which, IMO, would mean that the bike would be coming back up at him too fast (full force of spring and shock) for any jump much over 2 or 3 ft..
Old 11-20-2006, 02:41 AM
Marty's Avatar
Default RE: Shocks
I found it easier to actually remove the shock from the bike, compress the spring and then tighten down the collars.
That also gave me a chance to lubricate all the spots on the rear suspension that were bone dry from the factory.
Old 11-21-2006, 03:51 PM
M_O_Z's Avatar
Default RE: Shocks
i want to stiffen the back shock when i go play in the mud and in the fields and that way the shock doesnt bottom out bcz i have done that already to it
M_O_Z
Old 11-21-2006, 04:29 PM
Marty's Avatar
Default RE: Shocks
M_O_Z,
If you weigh more than about 145 pounds, you might want to think of getting a heavier shock spring!
Old 11-21-2006, 10:16 PM
M_O_Z's Avatar
Default RE: Shocks
i guess 200 lbs wont work then and the craziest part is im only 16
Old 11-21-2006, 10:37 PM
M_O_Z's Avatar
Default RE: Shocks
Then what type of rear shock would you suggest i put in then??? and a rough idea on how much it would cost and i dont have enough to buy a nitrogen filled shock
ninjabarmy
02-20-2007 05:56 AM
urnumberone
12-22-2006 09:04 AM
JohnnyfromBama
12-13-2006 11:42 AM
c10
ZRX1200
03-04-2005 07:39 AM
c10
02-06-2005 06:21 PM
Quick Reply: Shocks
