Shifting Problems
Old 08-14-2012 | 07:25 PM
TheBikeRider's Avatar
Default Shifting Problems
My KLX 250sf will not shift lower than 2nd gear. The Star shifter was broken, but i replaced it and I am still having the same problem. I then checked all the Pins and such but nothing else is broken or bent... Any Ideas?
Old 08-14-2012 | 07:45 PM
Pogiboy's Avatar
You said start shifter was broken. Are you sure theres no debris left inside that might interfere with the shifting? A small metal fragment might still be lodged inside. Hope you'll get this fixed. Ride safe.
Old 08-14-2012 | 08:42 PM
I thought the same thing but when i drained the oil the metal piece came out with it.
Old 08-14-2012 | 10:26 PM
doum's Avatar
It might have bent the forks that move the gear in the tranny.
Old 08-14-2012 | 11:35 PM
MaximusPrime's Avatar
Is it possible to put it in incorrectly, by which I mean, shifted or rotated one place over?
I don't know, it's just the kind of thing I would do if it's possible.
Good luck figuring it out!
I've crashed and bent my shift lever so many times I feel like I'm on borrowed time before I have to do this.
Old 08-15-2012 | 01:20 PM
System6's Avatar
Welcome, BikeRider.
What year is your bike? How many miles?
Check your clutch adjustment.
A little bit more free play than the thickness of a nickle is what most recommend. I like a bit more.
My first adjustment came at a little over 3K and I'm not too hard on the clutch. I couldn't find neutral and sometimes wouldn't shift at all.
Hope it's that simple.
Good luck.
Old 08-15-2012 | 02:10 PM
Its a 2009 but it only has 400 miles on it. Practically brand new
Old 08-16-2012 | 08:46 PM
Blackheart58's Avatar
Make CERTAIN that the shifter isn't hitting your frame, or bash-plate, or bracket. That can keep it from going all the way down to 1st.
Old 08-16-2012 | 09:18 PM
System6's Avatar
Make sure the clutch was adjusted correctly during prep at the dealer. Hope it's that simple.
Good luck.
Old 08-01-2014 | 05:03 PM
Jesse Abernethy's Avatar
I'm having this same issue after breaking my shift shaft.. Replaced it and now it has a hard time getting in and staying in first gear. Edit: My return spring pin was slightly bent up as well... resulting in possibly keeping the shift mechanism from going all the way down.. Ordered the $7 part and will advise.
bmrconstruction
01-28-2009 11:23 AM
walight01
02-12-2006 05:35 PM
bobsZL
12-28-2005 03:49 PM
jeck
11-04-2005 11:52 AM
toad1025
07-27-2005 04:30 PM
Quick Reply: Shifting Problems
