Shifting issues after lowside - reluctant into first, hangs on upshifts
Old 07-25-2020, 06:28 PM
RyYYZ's Avatar
Originally Posted by GBAUTO
I would complete the disassembly of the shifter pawl.
Inspect the shaft for any bending. Look closely at the attachment welds of the plate on the shaft(I've snapped those before.)
If all of that looks good, loosen the center pivot bolt and see if it wobbles as you unscrew it.
So, I found this thread here:
https://www.kawasakiforums.com/forum...r-shaft-43276/
which seems to describe my situation. I can't actually see that the mounting boss (or anything else) is bent, but something must be.
Old 07-26-2020, 12:58 AM
RyYYZ's Avatar
Problem solved!
I finally decided to do something I had considered before, and shim the old, bent return spring stud so it is installed 180 degrees rotated from its original position. With that done the gap between the pawl teeth and the star nubs was about even. Bolted it back together and it shifts like a charm now.
I'm going to go back in eventually after I get some better shim washers, new neutral disk (don't ask) and retaining bolt, and a new gasket for the cover.
timc63
07-28-2020 03:18 PM
Gwolf
06-01-2017 02:40 AM
Matt88-8
02-22-2017 04:56 PM
punkenduro09
12-08-2014 08:28 AM
FiveLiterRiceEater
09-12-2009 03:13 PM
Quick Reply: Shifting issues after lowside - reluctant into first, hangs on upshifts
