Shift Star Mod Install ISSUES???
That was me that had problems - I posted a couple threads on it...
I ended up grinding my own shift star in the end (copying the FSW star as best I could), and it worked well.
Remember if your neutral indicator is not coming on at the right time, then the lockout circuitry had better be disabled, otherwise you may not be able to start the bike. There is a circuit which disables the starter when not in neutral.
While were on the topic of shift stars, has anyone put one from an 09 in the 06-07 yet. I saw them from Ron Ayers for around $20. I was going to get one and see if it would fit but never got around to it yet. It would be a cheap alternative if it would fit.
Just a question regarding the neutral indicator???
I have not buttoned this up yet...That being said, my bike would start in any gear before I did this mod. I never had to have it in Neutral as long as my cluch was pulled in.
So...what do you all think about that? Would the neutral indicator still have anythign to do with it?
Thanks,
Im going to call Jerry regardless but I like the feedback!!!
MAXXX
Thanks,
MAXXX
Thanks,
MAXXX
Thanks,
MAXXX
To get around this, just bypass the kickstand switch.
right, I was confused... The lockout circuitry is in two places - kickstand switch and clutch lever... But doesn't it also matter what gear it's in? Naw - guess not. If clutch is in and kickstand is up, it will start regardless of gear.
Connection is under the seat. Trace the two wires from the switch to the plug, disconnect and join the two plugs left on the bike. (Not the two going to the switch. Remove those with the switch.)
punkenduro09
12-08-2014 08:28 AM
