SF 17" wheels, tubed or tubeless
Old 08-15-2012 | 12:51 AM
mtbcrossover's Avatar
Default SF 17" wheels, tubed or tubeless
Looking for clarification.
Thanks
Old 08-15-2012 | 02:17 AM
fooswolf's Avatar
tubed
Old 08-15-2012 | 02:34 AM
wildcard's Avatar
you can use tubeless tires but you have to run a tube inside since its a spoked wheel, unless you get a "tubeless" setup which still uses a tube of sorts but not in the traditional way.
Clear as mud ?
Old 08-15-2012 | 02:36 AM
ahnh666's Avatar
tubed, but i run tubeless tires with tubes right now after the stock tires wore/popped...the best tire sizes to run is 110/70-17 front and 140/70-17 rear...i'm currently running 120/70-17 front and 150/70-17 rear, and my mpg is lower and it handles like a slug...but, cruising straight on freeways is great and comfy...
Old 08-15-2012 | 03:28 AM
JoelThailand's Avatar
I run Pirelli diablo rosso 2 tires. These are a Bi-compond sport radial & definitely TUBELESS with inner tubes fitted. They make the stock IRC tires feel like wooden wagon wheels!
Old 08-15-2012 | 08:03 AM
Thanks for the info. I did not realize that you could fit a 150 in the rear. A lot of rubber for the little 250 to turn. I will think about it.
Old 08-15-2012 | 01:27 PM
ahnh666's Avatar
i have about 2,000 miles on mine with the 150 rear...i already have it on, so i'll ride on it until it wears, but i'll downsize to 140 next time...and, go back to 110 front..
Old 08-23-2012 | 06:18 PM
ranger01's Avatar
So I want to replace the crappy irc stock tires. Pirelli is out of the rosso II 140 rears. I'm thinking of the 150/60/17 and running a 120/60 front. My other option is the pirelli demons but I don't know if anyone has ridden with them. Any other opinions for street tires for the sf?
Old 08-23-2012 | 06:42 PM
wildcard's Avatar
I'm gonna try the shinko 006 for my next set i think.
Old 08-23-2012 | 07:44 PM
ahnh666's Avatar
i'm running 120 front and 150 rear...i regret it...handling suffers...it feels like a heavier bike on the turns...slower to lean left and right....i really recommend going with 110 front and 140 rear...
Quick Reply: SF 17" wheels, tubed or tubeless
