Sealant on float Bowl KLX250s?
To all
2006 KLX250s
I have the carb ready to go but I have a question on the float Bowl O-ring. I noticed a sealant “small amount” surrounding the O-ring. The sealant was applied in the valley then the O-ring was put on top. No sealant is on the top of the O-ring itself. I am buying a new O-ring and wonder what this sealant is? Is it necessary? The sealant must be fuel proof “Hylomar” or similar. Curious, any comments.
thanks
Stashu
2006 KLX250s
thanks
Stashu
Thanks for all the replies. I though it was some sediment in the bowl O-ring area. When I took out the O-ring I noticed the sealant. This is why I am getting a new O-ring. It has come to my understanding that a small amount is used to hold the O-Ring in place not to seal, I think this make sense.
Thanks!
Stashu
Thanks!
Stashu
I have seen that light brown color sealant holding the O-ring into the bowl on a few bikes. They must assemble them upside down on the line and glueing the O-ring in is a simple way of assuring a good seal and that the O-ring isn't twisted or torn by the carb builders.
If rebuilding or replacing the O-ring for some reason I would not worryabout regluing. A little hylomar wouldn't hurt if you find that the O-ring won't stay put. Amazingly, this seal never seems to leak despite being a large seal area, 4 small screws and thin gas on one side.
