SAFETY TIP: Check Your Brake Sensor Wiring
Just a small head's up. In case you did not notice it in my Acerbis taillight thread, I had a little issue yesterday that resulted in me finding a wire disconnected from my front brake sensor. To be honest, I had never even noticed that the connection was there, much less that one of the wires was disconnected. The result was that my brake light was not getting brighter when I applied the front brake, so cars behind me did not know that I was braking. Not good.
Anyway, in case you haven't noticed them, there are two small connections on the bottom of your front master cylinder - basically just below and in front of the kill switch. They look like they can come undone fairly easily if knocked, which is what I assume happened with mine. It would not be a bad idea to take a second to check those connections the next time you get on your bike.
My new favorite graphic. I'll be using the crap out of this for a little while. Sorry.
RE: SAFETY TIP: Check Your Brake Sensor Wiring
I'll check that out. But something that I do every time I get on the bike is to check all the turn signals, and that both brake levers actuate the brake light. I even catch my self waiting in traffic for a light to change looking behind me to see if the brake light is being actuated. I have been through 5 bulbs since installing the Acerbis DS tail light. I don't trust it. So do a safety check before you ride.....EVERY TIME!!!
ORIGINAL: deej
ORIGINAL: deej
ORIGINAL: ol guy
The original taillight was rubber mounted for less vibration. The arcerbis mounts pretty solid. Probably hard on the bulbs. When I was mounting mine I was wondering about that but noone had ever mentioned any problems. I'll keep a closer eye on it now.
ORIGINAL: deej
Checking fluid levels, stops lights (front & back), turn signals, hi/lo beam, mirros, and horn is my standard procedure during warm up. (I'm not **** about it, but they're easy checks to do while waiting ... )
Rubber mounting is good for filiment bulbs, but I'd still like to see if I can get the LED unit installed ... "Dam the vibration, Full speed with a LED!!!"
you guys do know that they make bulbs that will fit in that socket right......
http://www.superbrightleds.com/tail-brake-turn.html
They have them at parts stores too. just never got around to get one....
